Hello @kylekane, hello @Spyndel,
i just want to chime in and add that I’m having the exact same issue.
After experimenting with the parameters for a while, I got to this conclusion:
- The error (weird sound file instead of a movie) occurs when I have the the FadeIn and FadeOut times for the Title Image set to 0.
- When I have the FadeOut AND the FadeIn times set to a value above 0, the movie is exported correctly.
This is an issue when I just want to have a clean turntable without any logos, titles and fadeins/outs.
I tried to add a transparent texture, assuming that I could fade it in/out and it wouldn’t be seen. But this doesn’t work as the fades make the texture flash bright white anyways.
Specs:
- iMac late 2013, Core i7, 3,5 GHz, 16 GB RAM, NVIDIA GeForce GTX 775M 2GB
- macOS Mojave, 10.14.6
- ZBrush 2021.5
My workaround for the time being will probably be: create turntable with fadein/out and two spins instead of one and then cutting out what I need in a video editing software.
Hope this helps & happy zbrushing!
