Help! obj. import faces not visible?
I have some kind of strange problem i built a model on Max 7 and i wnat to export it into zbrush2 to add some detail but when i export the model (with settings under that other model work!) i get this:
model in Max
expoert settings
model in zbrush
Any ides what i did wrong???
the strange thing is i have a body part of the model that i dont want to esport now
and when i export both head and body all works fine!!!???
Thx
looks like you have some faces flipped in max,
try unifying them or inverting the ones that are backwards in zbrush while in max.
i believe theres a flip in the tool>displayproperties menu if memory serves me right but in zbrush it will show you the ones you can’t see now and the others won’t be seen so it’s best to fix them in max first.
ahhh it rally was the fliptool inside zbrush
(every face was flipped)
THX
