anyone mind posting a good way to make a fence texture (chain link).
I was able to do it using 3d cylinder, but there has to be an easier way,
heh.
I always seem to find the hardest way to do this stuff, to learn it could have been much easier.
heh.
By chain link, I assume you want a part transparent texture.
See the Zbrush picnic zscript, the part about creating the basket texture.
yeah, that picnic script is where i got the idea
i just wondered if anyone knew an easier way than using the cylynder tool and snapshotting, i seem to have a problem getting it all to line up.
Do you hust want a texture or do you need a real model?
If you just need a texture I have one you can use.
Here is a color map and a alpha map it is JPG format but I can render out whatever size you need.
Dave
Wafflez - If you want to model it instead, I just put a big model up on my site Wednesday for a lightwaver-
"Mike - since you’ve been looking so hard all night -
http://www.ultimanet.com/~jim/Images/chainlink.jpg http://www.ultimanet.com/~jim/Images/chainlink.zip
Sorry, it’s a monster (3.4 mb)
Jim McKnew
[email protected] http://www.ultimanet.com/~jim/"
It’s a 3ds model, but I can convert it to .obj if anyone wants it that way. Attached piture was as an .ob brought into ZB…
[IMG]http://www2.zbrushcentral.com/zbc_uploads/user_image-1036201541hef.jpg[/IMG
sorry, picture didn’t come through the first time…
thanks for all the help fellas
appreciate it
look in zbrush texture pallete there is a texture that looks like Fence Txtr 32
make it alpha then set your
Alpha:Blur,0
Alpha:MDep,3
Alpha:MRes,176
Then Make 3D
Zscript
Fence.txt
took about 7 to 10 seconds to make it.
this is for version 1.5 zbrush ONLY
