Hey guys, when painting a texture in ZB is there an eye dropper or color picker like in Photoshop so you can sample colors directly off the canvas? I’ve looked around in forums and help but can’t find an answer.
Thanks!
OK, I got it. For anyone else reading this you press “c” to color pick off the canvas.
You can also click and drag from a color selector. That will pick the unshaded colors like the shortcut ‘c’.
If you click and drag and then hold ALT you will be picking the shaded colors. The shaded colors are the actual colors you see on screen at any given time while the unshaded colors are the colors before any material or render adjustments are applied.
The Render > Flat mode shows the unshaded colors.
You can click and drag any color selector, for example, the Document > Document Background Color or the Render > Fog > Fog Color 1 selector.
:Dnice i always wondered if there was not a way to get the real color
If you want to save stuff for later my ZSwatch plugin allows you to pick, store and adjust shaded and unshaded colors. See the link in my signature.
Wow, those were really helpful. Thanks guys!
…the “Color Quick” by Aurick
With it you can Clic & drag inside 2 colors who are mixed between them for lovely palettes
Pilou
