Zbrush 5r6
First of sorry for my silly questions, I’m a beginner, just started with Zbrush a few months ago.
In my learning process, trough GoZ, I import from Poser to Zbrush Victoria 4.
I try to make a simple clothes by “subtool>extract” command as you can see in the photo above.
As you can see in the two above pics the extract clothes is penetrating Victoria skin, I try to underline it in blu, half of the extract clothes tikness is penetrating the skin.
I use the extract command with default values, I just change the Thickness command “0.009” and “S smt” command (I tried to give values from default 5 to 20) all with same results, the extract mesh penetrates the skin.
What I’m doing wrong? How can I extract the mesh without penetration?
I try to export the extracted clothes as an obj to Cinema 4d.
Once in cinema 4d, as you can see in the above photo, I end up with an object divided in many groups, circle in red. Goz imported Victoria to Zbrush from Poser with default polygroups assigned. What I have to do in order to export an obj with only one group?
Thanks a lot for your help and sorry again for my silly beginner questions.
