error: remeshing error encountered. remeshing aborted.
zRemesher errors out on every subtool I try to apply it to in my project saying “error: remeshing error encountered. remeshing aborted.” I googled it and found nothing. If I try it in a different project It works fine. It has worked fine in the past for the same project but I have no clue what could be causing the issue. I tried using default settings, no symmetry, checked for holes in the mesh and still nothing. Thanks for any help!
Did you try Fix Mesh in the Geometry palette? You could duplicate and then make dynamesh, a quick remesh/leave dynamesh followed by projection, or run Decimation Master on it and try again.
Well an alternative was just to export the mesh into a new project and re import it to the original project after the remesh then I projected the detail like originally planned. Ill try the Fix Mesh option in the morning to see if that would’ve fixed the issue. I just thought it was odd that every tool was affected even something as simple as an appended cube so I’m assuming that it was related to the project as a whole. Thanks!
