Error encountered while loading a tool
upon opening a Zbrush project I get this error message.
The project does open, but I have to redraw a tool, and some tools are missing(the troubled tools I’m assuming).
I have done numerous tests with the project files and have determined that when copying tools or subtools, will cause this to occur.
When I copy and paste, clone, or merge visible subtools this seems to be creating corrupted tools. Saving them out as a ztool and reloading will also create this error upon re-opening the project.
Now if I use a default polymesh like sphere or cube and append subtools over onto it the project has saved and reloaded porperly…(so far).
I have only encountered this problem in the last few days, and the only thing that has changed in my workflow is an increased use of the Z-modeler.
This is very frustrating because I have a alot of IM brush creation,copying and re-use in my current project.
Any help would be great
Thanks.
Is this just happening with the one project, or with several?
Right now it’s just the one project, but across a few iterarations, so it doesn’t happen in earlier versions of the project only the recent ones, and I haven’t seen it happen at home yet.
Not sure but I think these problems increase when you save and load the undos, set in the preferences menu. I had recently the same problem and I discovered that save and load undos have been set on when normally they are off. No idea how.
Thanks.
I wish it was that simple, but I haven’t saved or loaded the undos, for a couple of years now. I did have major problems before I turned em off, like why my files were taking so long to load. It’s definatley something that should be off by default.
Sadly those problems appear when Zbrush has not crashed by a long period, something that makes impossible to know that the incremental files are all wrong. I nearly prefer that it crashes periodically as usually does. It doesn’t affect me as I save very often. :wink:
I’m experiencing the same problem. I have several projects from different times of the year, all have different iterations of the ztool and i can’t load them on any version of Zbrush or even on different computers. I don’t get it at all how only certain projects won’t load. If it has anything to do w. what was said about copying, cloning or merging subtle, then that is a huge problem and pixologic needs to fix it.
I was one of the designers of Killer Croc for “Suicide Squad”, did a whole bunch of different variations of him, turntable vids, other stuff and now all those files are corrupted and I can’t load any ztl or obj file on any version of Zbrush. luckily, that show is done, but it scares me that this could happen again on a project while i’m working on it.
Even though you haven’t saved undos I would give “skip loading” under Preferences / Undo History a chance.
Maybe there is something corrupted in this part of the file.
Takes only a second.
Bon chance!
