I’m trying to make my character (which has ~2.8 mil polys currently) more detailed, DynaMesh is set at 2096, and when I max it out it doesn’t add any polys, even after I edit my mesh. Size of the mesh set at 2. When I max out DynaMesh it doesn’t really add polys, even after I edit it. What should I do?
And also, when I pick the res from my model DynaMesh gives me res around 700-800
Hello @asiimov
There are multiple factors at work here.
- Please review the Dynamesh documentation. In the first prargraph it mentions the tool is for the rapid development of form up to about a medium level of detail. It is not a tool for capturing of fine detail. That will require subdivision and detail projection.
http://docs.pixologic.com/user-guide/3d-modeling/modeling-basics/creating-meshes/dynamesh/
If “Project” is not enabled, the mesh will not update itself with further Dynameshes unless you make a change to the form, even if you alter the resolution slider. It will not update the resolution until you make a change to the form and force it to update.
The maximum polycount potential is determined by the value of the resolution slider and the surface area the mesh occupies in the bounding box. So a cube that perfectly occupies that space will have a higher polygon potential at max res than a long, thin cylinder that has much less surface area. The resolution picker is sampling the size of the polygons in a given area.
For most typical meshes, this means the mesh will cap out at around 3-4 million polygons at max resolution.
Good luck!
