Does ZBrush 2025.2.1 not work with Keyshot 10 Pro?
As titled,
Trying to use Keyshot but it kept showing that the license doesnt support live link for ZBrush and need an upgrade
Do I need to upgrade Keyshot 10 Pro to 11 (which is subscribing to it)?
If I dont upgrade is Key10 Pro dead to ZBrush 2025?
thanks a bunch
Kevin
apparently the new ZBrush 2025 2.1 doesnt work with Keyshot 10?
Keyshot support:"Thank you for your response. I’m afraid the ZBrush integration and plugin are developed and supported by Maxon, and it appears their plugin is not version-independent—meaning it may no longer be compatible with older versions of KeyShot.
Unfortunately, we’re unable to make changes to third-party add-ons, and I’m sorry for the inconvenience this may cause.
If you have further questions, I’d recommend reaching out to Maxon’s support team to confirm whether live linking with ZBrush 2025.2.1 is compatible with KeyShot 10. Based on the screenshots you shared, it does not appear to be supported.
I hope this helps. Please let us know if you have any other questions."
