Does the scroll wheel do anything?
I found several posts about using the mouse scroll wheel to zoom (which would be awesome) but that seems not to work any more - even when i try to do it in the document menu it doesn’t sense the scroll wheel. But it won’t even scroll the menus on the right. It appears the scroll wheel had been disabled. I’m on a Mac, using a Logitech mouse in ZBrush 2020/
Hi @BTSculptor
The “In” and “Out” (zoom in and out) buttons are in the Document menu. You can Hotkey your scroll wheel to those 2 buttons. Make sure the cursor stays on top of the buttons when you do. eg: hold Alt+Ctrl, click on “In” button then scroll the mouse wheel up. I’m on PC so I can’t give you the lines of script that would go in your DefaultZScript file because the key numbers are different. If that doesnt work, you should submit a ticket to Support.
Note that a tablet is listed under the recommended specs for Zbrush. The program is designed around the use of a tablet, not a conventional mouse.
Just FYI I have logged this issue w. a support ticket and was told it was being worked on…we shall see. #Ask Zbrush has a tutorial on how to program it with the mouse wheel so it should work. It’s a Mac issue.
I use both
