I’m having some trouble understanding how to get the best quality render pass from ZBrush into Photoshop, with regards to dimensions.
I’ve studied a couple of tutorials but I end up being more confused than I started.
I’m looking to produce a photoshop file which is 160mm wide x 200mm high @ 300dpi. After creating a new doc in Photoshop using these dimensions, the image size conversion is 4800x6000 pixels.
From what I understood from the tutorials these figures (4800x6000) need to be input into ZBrush and then doubled. However you can’t go over 6000 in the Document size.
Are there any resources that explain the conversion clearly rather than a step by step procedure. I mean understanding why you’re doing something is half the battle when learning.
Any pointers would be gratefully received.
