Displacement map setting in zbrush for iclone 8 and cc4
hello
i have many problem to configurate setting in zbrush to use displacement map in iclone 8
when i use original test in zbruch (with many balls in 3d ) and i export this test in iclone every time the mesh are no good with surface open
if you have the good parameters in zbrush
thank you but ther are many many possibilities.
:smiley:
for exmple i have this problem.
all configuration on Zbrush and aproximatively the same result … dv32bit or without … with luv or not … with dvlnormal or not …
