Creating a custom menu, What is the correct way to get the SubTool Palette to work?
I’ve tried it directly in the menu, and in a sub menu, with the same results.
After moving the slider to scroll through the SubTools, all SubTools Visibility disappear a from the list.
Unfortunately, the subtool list is one of those interface items that won’t work with a custom UI. It’s a limitation with custom arrangements that they depend on the name of the interface item. As the subtool list changes depending on which tool is selected, if you add it to a custom menu it will work for the tool that you used but will give errors with others.
Thank you for a clear understanding of “the why”. I stopped after a few ZB re-starts to make sure it wasn’t me doing something wrong.
well… i beg to differ… i did it… stand alone sub tool
pallet
