Yesterday, i’ve changed my custom layout… and after i removed all icons from my bottom shelf, it dosnt disappear like usual!
any tips?
thanks!
any tips?
thanks!
Hi @wizz216
There might be something hiding that you can’t see. Move your cursor down to that spot to get a double arrow then hold down Ctrl and slide the shelf left and right to reveal more.
No that i already did, there are no hidden buttons, or spacers.
That’s strange! Maybe the left shelf is holding it back for some reason (although it shouldn’t) as it extends down to that distance. Maybe try sliding the left shelf up temporarily to see if it makes any difference. Other than that, I have no idea why it would do it. Maybe ZBrush Support might have an idea.
Thanks a lot for your time!
I guess i have to ask pixol…maxon
If you recently changed your UI layout, it’s possible you forgot to turn off “enable customize” in the Preferences menu, which results in this.
