I noticed that when I import some objects into ZBrush, their axis of symmetry is off. Is there way I can adjust the axis of symmetry. Right now the x-axis red dots are not lining up properly. Thanks in advance.
Try Deformation:Unify
I believe he’s looking for y or z symmetry. You can find the symmetry options in the transform menu
The Local Symmetry button changes how symmetry behaves. You can also use the Transform palette to set new pivots.
http://docs.pixologic.com/reference-guide/transform/
Also there’s Resym and SmartResym.
