4R8 Multimap exporter problem
I am trying to export maps from 2 subtools. I make them only visible and set subtools button to on as well as merge maps. But the wrong subtool is exported (one that is hidden).
I started this model in 4r7.
Any ideas about what could be causing this?
There’s a known bug with MME which will be fixed very soon. In the meantime, copy the two subtools to a new model and export from there. The plugin should export up to 4 visible subtools.
ok thanks Marcus!
I isolated 3 subtools and the displacement used only 2 of them…
Is there any way to open back a scene in 4R7? When I try I get an error.
I’ve sent you a private message.
