Hi!
It seems like Zbrush 2021 doesnt respect imported obj scale. Whatever scale I export from blender or other apps Zbrush imports the same size.
Please, hotfix needed.
Hello @Feddark
If you import a tool into ZBrush either by default, or into a tool with an Tool> Export> Scale Factor of 0, it will be auto-scaled and auto-centered to a Tool > Size.> XYZ of 2 (approximately). This is both normal and necessary for proper ZBrush function. This video explains some of the reasons why.
It records the values to restore the mesh to its original size and position in the Export menu, and as long as those values or the mesh itself aren’t changed, will export the tool back at its original size.
I don’t see any indication it’s working differently than normal here. However, if you ever encounter a technical issue in ZBrush, that needs to go to Pixologic Support. These are the community boards where other users like yourself discuss usage questions, not a direct line to the developers.
Good luck!
Thanx for advice!
Seems like my problem was related to elaborate pipeline that I wouldnt recomend to repeat at home =D so my files get kinda corrupted in some way =D
Anyway thanx for reply!
Good day!
