zoom on cursor??
Can someone tell me why I can’t zoom to where the cursos is? When I want to zoom in on the face of my character, it always zooms to the center of the model. Seeing as how this is a lizard it zooms nowhere near to where I want. I can’t believe that this is the default setting. Is there a way to change this?
Thanks
Allen
Turn on Transform>Local. This tells ZBrush to scale and rotate relative to the last edited point rather than the model’s geometric center.
Alternatively, hide part of the mesh and press S.Pivot on the right shelf. This will change the pivot point to be the center of the visible area. Pressing C.Pivot returns it to normal. Note that this option affects symmetry while working on your model. In some cases, that’s very helpful, but in areas where it would be a problem you should use Local Transform instead.
nice. exactly what I wanted to know. Next I need to work on figuring out the projection master.
Allen
