Hi there.
I was wondering if it was possible to modify IMM brushes in ZbrushCore.
The shapes that come up with the default IMM BParts or IMM Modelkit brushes are good but do not serve my purpose. Can I create new IMM brushes with shapes that I want for my character? Or maybe add new shapes to existing brushes. Like can I add a plane to IMM Primitives brush other than the cube, cylinder and sphere that it already has?
No, I don’t think that’s possible. You’ll have to add the parts as subtools and then merge, or use the Tool>Geometry>Modify Topology>Insert Mesh button. If you use Insert Mesh then you can mask the base mesh and move the inserted mesh around using the Gizmo or Transpose Line.
Thanks Marcus. Thats what I was thinking about doing initially but since it was quite slow, started exploring IMM brushes for the task. Maybe those brushes will come handy some other time.
