ZbrushCore and "30" brushes
I’d like to say that I’m a little ticked off that the Zbrush Core page says, “Number of Brushes” and 30, but doesn’t mention that you can’t have any custom brushes. I thought it was limited to only 30 available at a time, not that it was limited to the 30 they deem most important for new users. From talking to other Core users, none of us can figure out how to add custom brushes, and most are convinced now it can’t be done.
But that brings me to my actual issue. I’m no math wizard, but these are the brushes, and … I only count 26.
Where are my other four brushes?
Dare I dream… can I add other brushes?
-Chilton
There are five additional brushes in the ZBrushes folder (or thru the Brush tab in Lightbox). You can also modify an existing brush (for example, by changing the Stroke or adding an alpha) and then save it.
It’s not possible to load ZBrush content into ZBrushCore but that doesn’t mean more content won’t be made available in due course.
How do I found more brushes as mechanical part to make robot? As show in the video
//youtu.be/uz4v1Eq1IGw
Please a good responds as provide more information
It will more appreciate.
Thank you!
Please add clipping brushes. Pretty please :smiley:
max30w,
Select the IMM ModelKit brush from the Brush palette, then press ‘M’ on the keyboard to show the IMM ModelKit pop-up.
