Hello there,
I was reading primers on ZBrushCentral for how to create DLLs for ZBrush, and how to get them to run. I know I use [FileExecute] to call the DLL and pass functions to it. But my question is:
How do I get my DLL to ‘communicate’ with ZBrush? Let’s say I want my DLL to execute ZScripts from its side of things. How would I go about doing this? An example is shown in the pseudocode below:
string cmd = "[ZScript CommandA]
[ZScript CommandB]";
ZbrushWindow.ExecuteCommand(cmd);
I have a script that speeds up my pipeline quite a bit. But the problem I face is in its call to UVMaster. Since that is a separate script, my script will terminate the minute it’s called.
I want to find a workaround for the ‘one zscript at a time limitation’. I figure if I can get my script working, I can call THAT, then send it over to the DLL to call the 2nd command in another script, and then return execution back to ZB or something along those lines.
I also know python, so if that has to be a recommended route, I’ll use it. But I also know that not everybody has Python installed on their system. So yeah.
Can anybody help me out? Thank you kindly.
