Hi all,
When I export a particular mesh from Zbrush, the resulting mesh gets stretched out over a much longer distance, with all the vertices on two flat planes on either end. I’ve not had this problem with any other meshes, just this one. I’m importing the OBJ into Max 2008 but I’ve exported it from Zbrush and reimported it straight back in and get the same result, so the problem seems to lie in Zbrush.
Any ideas would be greatly appreciated, I need a solution urgently!
