The problem occurs.
Why object disappear?
I use transform move, and rotate and … the objects , other not selected objects becomes invisible.
This problem makes it difficult for me to work.
I’m sorry in clumsy English.
Takuto
The problem occurs.
Takuto
Unselect “dynamic” from the Solo button
I don’t select dynamic solo.
This problem sometimes occurs .
The problem, but not always occur, but it is difficult to work.
When I select tranceform move, scale ,and rotate,(defolt right shelf button)
The object , it appears as if I have selected a dynamic solo.
The problem occurs only when I press the button move , rotate, scale(defolt right shelf button).
Takuto
The word “Dynamic” on the Solo button should be turned off:
Are you sure yours is turned off?
It’s easy to hit the button within a button like the one for Dynamic Draw size
I understand.
but it is selected sometimes without push dynamic…:evil:…why?
Thank you.
Takuto
In that case, I don’t know what is happening.
Is it ZBrush 4R6 P2?
4R6 P2
I don’t know why the probrem happens…
This probrem sometimes happens…
butwhen I click the bottun, The problem disappears.
and I shink …Well ,OK…
