Hello! I am trying to cut the head of a subtool, but the trim brush is not cutting the piece I want. So I tried putting the trimlasso over the body, and I still end up with the head? What am I doing wrong? I froze my subdiv levels, I went to the lowest one, I literally tried everything. Help!
Instead try slice brush.
The Trim-Lasso function has a bug: It doesn’t work like other brushes (CTRL-Shift or CTRL-Shift-Alt to mark the parts to hold or to cut away):
It works a little bit other:
Making the Lasso clockwise is like CTRL-Shift and making the lasso counterclockwise is like CTRL-Shift-ALT
I Hhpe this helps you.
mawag 01
