What confuses a lot is the fact that a lot of options regarding a certain task are somewhat spread across the tabs. It takes a moment or two to tie those together. Once you got it then it even makes sense. Till then you can become rather frustrated. One sample to illustrate that:
You Z-add ‘stuff’. It’s coars and you wish to smooth it. You select the shift button and the smooth circle color (blue) shows up. You ‘hit’ the model with it. And ARGHHHHHHH all is flat in a jiffy. Now… try to find the strength slider for that… You have to go to the transform tab, slect the SMOOTH brush. THEN the Intensity slider is setting the smooth intensity. Once you set it, it stays at that value and you can switch back to the other brush you used.
One would expect that if you hit the shift key, the intensity slider also becomes the intensity slider of the smoothing brush… Not so in ZBrush. It is filled with little interface quirks. The main taks in getting familliar is to incorporate those little gem’s. Then… the deisgn emerges and you can operate it effectively.
Good luck!
Lemo
PS: And don’t forget. A puppy is shot, a kitten is drowned, and another ogre is model’d for every post in the wrong forum. So take care and read the stickies before you post!
