Vampire (30 days of night style)
Hi all I´m trying to make a vampire with the style of 30 days of night movie. Right now I´m finishing modelling of the head. Any comments are welcome :smiley:
Cool model! I just watched the film a couple of nights ago. Are you planning to do the full body? I think maybe the expression needs to be pushed a bit further. Any chance of some more angles?
gj mate:) congratzz… but i thnk you can try to detail your charachter
Hi guys, thanks a lot for your commentsFinbo- Thanks body, sure, I´ll try to the angles a little bit more. About the body, not sure yet, it depends if I have the will to do the full body, but right now I think I will :slight_smile:
halox- thanks man, yeah, I can try to add more detail, you have any ideas on where to start?
Hi guys, more updates, Here are some changes in the face expression and a texture starting render. Hope you guys like it and give me some crits to improve it :slight_smile:
I´ve been busy, so I have not been able to post any advance :frowning:
I´ve finally decided to come up with all the body :):slight_smile: so here is a little update, the shoes:
how did do the laces!!! I’m working on boots for my character right now… I couldn’t figure out how to do it.
Hi rich8606, the laces are made in max, not in zbrush. They are just a line with volume :wink: you probably can do that with any software you use, and the import it into zbrush if you want to. Hope this helps you, cheers.
The starting of the clothing, any help now will be great thanks guys:
The model definitely has some potential, but the material you have applied to it is killing it for me. :-/
I realize it’s probably just what you use for the work-in-progress, but maybe try a flatter, less contrasty material to show off your work?
Thanks for the tip zerodean, I´ll keep that in mind. Here is the hands modelling, with the classic zbrush material :wink:
Still many details to add, but it´s going foreward
I keep going, getting close to the end
It may be a little late in the game, but these vampires dig into the ground when the sun comes up. Might want to show a lot of dirt on the clothes as well as the clothes being tattered due to them digging and rising from the ground. Im also sure that the people they have killed have pulled and clawed at the vampires clothes as well.
Looking good so far!
Very good scene man! Totally different than mine. http://www.zbrushcentral.com/zbc/showthread.php?t=56653
It does worth a good rate!
:+1:
M
Hi guys, thanks for the crits and support :slight_smile: :slight_smile:
DAnconia- Thanks a lot for the info, I didn´t know that :eek:. I´ll try to add some dirt to the clothing, but not lots of it, I´d like to keep the vampire kind of elegant ;).
mik76- Thanks a lot budy!! Thanks for the rating, really apreciate :o. I´ve check out your thread, keep up the nosferatu work man!
A oclusion render and the probably final pose:
Changed a little bit the arm in the pose. Here is the probably final image, hope you guys like it, and any comment is welcome :slight_smile:
It’s pretty nice. Legs look a little stiff, but overall there is a good bit of emotion in the pose.
