Using Smooth Brush with Sculptris Pro - not working?
I’m trying to add some local geometry to a low-poly mesh using the ‘smooth brush’ set to “0” (zero intensity) with Sculptris Pro. I’ve seen this technique explained in a video by Michael Pavlovich, but as soon as I hit ‘Shift’ (for smooth brush) then the Sculptris button is greyed out… and I can’t add any geometry.
Are there any settings that I’m missing or is this feature gone in Zbrush 2022.0.5?
Hope you can help. Thanks!
Replying to myself, but I found the solution. Didn’t know that I had to ‘enable’ Sculptris Pro in the Brush-menu for each brush also… including the Smooth Brush. But now it is working for me. :blush:
sculptris-enable-menu
Thank you for replying to yourself! it helped me!!! XD
