UPDATE: I was a bit hasty here. I’ve checked further, and there are a few lines in AltView that need updating to accommodate ZBrush3 changes. For anyone who wants it, here’s a working version of AltView for ZBrush3. I’ll be creating a whole new thread to formally present the new version in a day or two.
Zwe,
First, thanks for the info on custom menus…
I just tested AltView with ZB3 and it works fine. (ignore the reference to ZBrush2 in one of the popup window screens.)
If you want to try it, download the AltView.zip file and dump the contents into your ZPlugs folder. Next, you should store those alternate .cfg files you want to swap through in the ZBrush3 folder…
Restart Zbrush and in the Preferences>Config submenu press on EditView which will bring up the UI list which will be blank. Click in one of the five empty name slots and, in the directory dialog, click on one of your custom UI files in the zBrush3 folder… repeat until you have as many as five alternate UIs in your list, then press Done.
Now, and any time you use ZBrush in the future, you tap the backslash key and cycle through alternate views! Replace views any time by going back to EditView.
Sven
p.s. any questions or problems, just ask.
