So far I can only find the insert multi mesh for primitives, the default human parts, and the model kit. Is there a way to add more? Is there a way to add your own models into the multi mesh tool? I want to be able to make small, low poly models and then insert them like you do with the model kit without having to go through the pain of using subtools and having to carefully position each one.
Is there a way to mirror a subtool that has been inserted? Say for example, you insert a sphere and then move it to far right on the x-axis; is there a way to make a copy of that sphere appear on the left side of the x-axis without having to try and do it manually?
EDIT: Thank you for the responses! They helped a lot.
