Does anyone know of a good tutorial which illustrates how to combine two (or more) subtools and create a seamless joint ?
ie : Seamlessly attaching a head model to a neck/shoulders model.
I have a feeling that topology is involved, but I’d love to see the correct steps towards getting the best and cleanest result.
I found the below, which seems close to what I what, but does not mention anything about smoothing the joint to crate a continuous mesh.
Combining SubTools
Before combining subtools be sure that your computer will be able to cope with the polycount of the combined mesh. This must not be greater than the maximum for your system.
- Save a copy of your ztool so that you can retrieve it if necessary.
- Selecting the primary subtool, switch to the highest subdivision level and then delete the lower levels. [Geometry subpalette]
- Press Tool>Clone to create a copy of the subtool.
- Repeat steps (2) and (3) for all subtools.
- Select the clone of your primary subtool. Then press Insert Mesh in the Geometry subpalette and select the first of your subtools from the popup. It is added to the mesh.
- Repeat step (5) until all subtools have been inserted.
Thanks again, this community rocks.
E
