Transform Type:Bend Curve Interface item not found
Hi, i`m trying to make a script that gets back my curve from the undo stack but whenever the following command is called it gives me an interface not found error?
I tried having the customize menu visible before running the command too but it doesnt help.
[IPress,Transform Type:Bend Curve]
Hi @Leslievdb ,
what is the “Transform Type:Bend curve” ? is it something you have created ?
It seems the script can’t to found that button so it probably do not exists.
best regards,
Nicolas
it was recorded on a macro.
it should be the command to switch to the bend curve mode
