Transform-> Draw Draft Analysis makes model turn black
No masking, or polypaint or textures. When I try and turn on the interactive display of draft analysis, the model turns black until I switch it off.
Hello @Crusoe_the_Painter
I can confirm this. Looks like a bug. Does not happen in the previous version.
If you’d like this issue to receive technical attention, it must be reported to Pixologic Support.
Hi @Crusoe_the_Painter
It works with Polyframe (Shift+F) turned on, in case you need to use it until the issue is fixed.
