Hi I’m using ZB4R4 with multi map exporter and although it appears to be writing the tiffs fine (32BIT) when I load them in any other app such as nuke, photoshop or mudbox, they report an error reading a strip, missing bytes.
I get the same problem if I bake with the standard DISP exporter
Has anyone had any problems with this ?
The other question I had was whether anyone knew if Multi Map exporter can write OpenEXR ?
