okay got Zbrush installed on it [7day eveluation for now…to see if i want it on there perm or not]
now…
bottom line is it any good for z brush?
…yes…i like it. there are some things to note though…
the pen.…only the hp pen works…my bamboo and blue slate pen do not work so don’t think your intuos pen will either…i’m guessing the hp pen has some different way to communicate even though it’s a wacom tech screen
tablet mode 100%
when you use zbrush in 100% tablet mode ie you have the screen folded ontop of the keyboard your obviously left with just the pen functions and the zbrush U.I
now here’s a weird thing…you’d expect that having your hand ‘on the screen’ would be not as good as using a off screen tablet as it will constantly obsqure parts of your model by being there but i actually get a great feeling that i’m somehow ‘more connected’ to my model…it feels more tactile to me as though you actually have a model ‘there’ under your hands…now that doesn’t make me be able to make BETTER models but the feeling does make me want to use and play in zbrush more…so more time should mean better at modeling!..like i said …weird!
in 100% tablet mode downsides>>[landscape]
so…how do you hide parts of a mesh and reveal them…you can’t…or i havn’t found the equivalent ‘u.i. button’ as yet…maybe there’s a way to add a button…any ideas?
same with painting a mask…no u.i button to take you into that mode.
the esaure end of the pen sculpts into you model whilst the nib pushes out when using z add…as you’d expect
the button on the pen is pretty crappy…doesn’t feel easy to use yet…mind you i’ve never got on with buttons on any pens really well as yet so that maybe just me…
the screen size is fine…screen res is 1200 x 800 on the 12.1" screen btw.
tablet 50/50% mode… [landscape]
now you can spin the screen round and NOT fold the screen onto the keys…
this saves space…your sreen is tilted at around 30 to 45 degrees…in this mode you can have access to the keyboard though you can’t ‘see’ the keys it’s not hard at all to put your other hand resting on the shift and cntrl keys so masking and hiding/revealing polys is simple again…
getting to the alt key is not so easy but with practice you could learn where it was without looking i reckon.
100% laptop mode [landscape]
just like a normal laptop you have access to all the keys on the keyboard and the trackpad plus you can use the screen to draw/sculpt on…this is the lowest learning curve way to get on and if you have room where your sat then it’s works really well
say on a train/plane/bus/small car
flipping the screen around
now you can run the screen in 4 ways…
1.landscape with the bottom of the viewport where the hinge is
2…landscape with the bottom of the viewport where the top of the screen is
3.portrait where the hinge is to the right of your screen
4.portrait where the hinge is to the left of your screen
now…in portrait mode [4] zbrush flips the pen so everything is reversed…up is down and left is right…so not working well!..i’d guess you could recallibrate the screen to make it work but then i’d also guess the other 3 modes would then be flipped out…maybe…!
now this is down to zbrush…windows is fine in ANY mode and i just checked with 3dsmax…it works okay in all 4 modes…
maybe a bug fix will solve that from pixologic.
re pressure sensativity
it’s as good or better than my wacom bamboo medium…i’ve also not set anything up…this is the factory settings out the box…works really well so far.
re heat from the laptop
as it’s a tablet pc there will be lots of times you’ll have this actually ‘on your lap’ and not your typical ‘laptop on a desk’ so heat is going to be important aspect…
the main vent on the HP is on the back right corner so you’ll need to keep that clear and not have your hand hold that corner as hot air is blow out when the fan runs…which is not all the time btw.
i’ll post more later
