Symmetry Off Axis
My model was working fine, then I saved the tool and when I reloaded it my axis of symmetry was off. You can really notice it when turning on symmetry, ‘x’ key.
Here are a couple things you can try:
  1. Turn on Transform>S.Pivot. This will temporarily set your pivot point to the center of the visible mesh. That affects symmetry.
  2. Press Tool>Deformation>Unify. This will permanently set the model’s axial center to its geometric center.
Thaank you so much!! aurick!, im just having a nightmare with this same issue and now the symmetry is working! with the unify tool!
