I recently painted a surface in HD Geometry mode using the rake brush to produce some wavy lines. I had about 10 million polygons, so the resolution was very high, but nonetheless, the rake brush produced lines with a sort of low-res “stutter” in them (hard to describe but I hope it will be apparent in the screen shot I’ve included.) How can I make that stutter effect go away? I tried modifying various brush settings, but wasn’t able to eliminate it. I’m using the standard alpha that comes with the Rake Brush, and did not modify it. I’m using ZBrush 4R7.
