Storing Lightbox reference position/scale [Solved]
I’m using lightbox as reference for head modelling. I have several camera angles photos and swap between them at same time that I rotate the model.
But they don’t remember size or position. When swapping between different camera angles of a face in lightbox I need to resize and position them each time.
Is there any way to store the size and position of all images of a lightbox?. The idea is that we swapping between them they will remember it and I don’t need to keep repeating the same actions.
Double clicking makes the images to align in a fixed standard position. This could be a compromised solution but it is always aligned to the left of the screen and not in the center.
LightBox isn’t really meant to do that. There are a couple of other possibilities.
http://www.zbrushcentral.com/showthread.php?178732-Use-of-spotlight-just-for-image-reference
http://www.zbrushcentral.com/showthread.php?179771-Image-plane-approach-Answered
http://www.zbrushcentral.com/showthread.php?179722-undo-to-include-everything-like-rotation-of-the-mesh&highlight=Timeline+store+views
Saving the “Spotlight” (Texture menu > ‘Save Spotlight’ button) will remember the sizes and positions of the textures. Then you can load the Spotlight (Texture menu > 'Load Spotlight" button) whenever you want.
Spotlight info HERE.
You might consider using the Grids for your reference images. They are a better way of matching the image to the model view. And if you like having images on screen to refer to you can use SpotLight as well. See here:
http://docs.pixologic.com/user-guide/3d-modeling/reference-images/
That link is great as shows a large number of options that cover all possibilities. I consider my problem solved. :smiley:
