(1) In the right-hand side of the menu above the selector initiated by Lightbox, I have this terrible mishmash (see image). How can I fix this ?
(2) In this area, how can I restore it to one row, instead of two high (again, see image) ?
(3) When I have actually set a texture using the spotlight, I remove the spotlight widget using Shift-z, and then click z to start painting. The problem is that I expected the overlaid texture to disappear before I started painting, but it did not. How can I fix this ?
Make sure you turn off ZAdd if you don’t want to sculpt at the same time. The RGB Intensity slider and Draw Size will affect how much color is transferred.
