In ZB2018 How exactly to set the default QuickSave path?
also what’s with the reverse “/”?
Current path:
C:\Users\Public\Documents/ZBrushData/
Custom path: (is this the correct syntax?)
D:\ZBrush/ZBrushData/
Current path:
Go to your “Users/Public/Public Documents/ZBrushData2018” folder and you will find “ZBrushQuickSavePath.TXT” file. Edit and save.
Got it, was in YE OLDE 4R8 datafolder. thanks!
How to operate it?
I don’t think ZBrush cares which way the slashes go, but on Windows, it’s probably better to use backslash (). I just used D:\ as the path. ZBrush will create the folder itself.
Win10x64, followed the instructions and used this syntax and it works.
perhaps a ZB Guru can explain why the “/” is used
