Smooth edges? (answered)
I have a problem that I cant figure out.
How can I smooth boarder edges (the edge of the mesh that has no thickness)?
Probably very easy or!!!
/Sjogren
Mask out everything except the midle poly that is in between the left & right poly, then use Geometry -> Crease.
I think my explanation was not so good!!!
Is it possible to make the smoothbrush smooth edges?
When i use smoothbrush it ignores the vertices att the edge…
/Sjogren
If I understand what you want, you have to go to the Brush palette > Smooth Brush Modifier and set the Min Conn slider to 1. Basically the value of this slider tell Zbrush How many points at minimum need to be connected under the brush for the smoothing to effectively be apply.
Thank you, that was exactly what I was looking for…
/Sjogren
thanks so much, this was driving me crazy
