Simple Brush Problem
The SimpleBrush don’t seem to work. I tried most of the other tools, worked great.
Any tips?
The brush don’t appear. I can only see squares. Is it a problem with my video card?
It sounds as though you have somehow switched off the alpha. You could try selecting an alpha in the alpha menu, otherwise does the problem persist after a restart?
See my answer to your other post (above). This screen shot is not a lot of use in seeing your problem as you don’t have the Simple Brush selected (you have the Fiber Brush selected). Also please don’t post more than once with the same question - it simply clutters up the forum.
I put the fur thingy just to compare.
I reinstalled the software and it works now.
