Rotate view in 45 degree angles?
Is this possible? Kind of like you rotate in 90 degrees by holding shift?
There’s no direct way but I made a little plugin that you can set the degrees for rotating incrementally. Seethis post. It works fine in 4R7 - install in the ZBrush 4R7\ZStartup\ZPlugs64.
Thanks, Marcus. Combined with “store view” in the image plane sub menu, this works perfectly.
