Rectangular dragged alpha brush not planar
Hello, I hope you can help me out. I created an alpha from ZDepth out of Blender. The Format is 32 Bit OpenEXR. When I drag the alpha of it in ZBrush, the geometry is not planar. It is bulged at the corners. Focal Shift is at -100. Radial Fade is at 0.
Thanks in advance.
I can not see the stroke you are using but assuming you are using dragrect. The curve section in brush menus affects the shape of the brush. If you want to avoid this change the curve to a flat shape. Otherwise you are always having a blending between the alpha and the curve shape in the brush. In fact you can use this to do effects or to do new shapes without changing the alpha.
Yes, it is dragrect. The curve settings helped! Thank you very much. That was exactly, what I was looking for.
