Quick Save path won't work anymore?
HI!
So my drive filled up and I needed to move it to another drive.
I went from Z:\QUICK_SAVE 2023 to S:\QuickSave
But every time I start zbrush, it goes back to the default quick save path.
ANyone run into this??
Thanks!
Hi @louvfx
Make sure you have the correct path in the “ZBrushQuickSavePath.txt” file in “C:\Users\Public\Documents\ZBrushData2022” (your version different).
Yup, it’s in the correct path. For some reason it keeps reverting back to the zbrush default path regardless what path I put in. I gave up and just added the quick save folder to the LightBox folders. So frustrating…
Thanks anyway
I’m having the same issue here and recently moved to 2024.0.4.
Along with the query above, what can be said about the scratch disc pathing? Can this be changed as well?
