Questions - Transpose Units
Is there a way to save the transpose units settings (preferences>Transpose Units) as the default configuration? Is there a way to increase the size of Axis Length beyond 250 (in the preferences>Transpose)? Is there a way to make transpose automatically measure a model without having to click, hold and drag from top to bottom (to measure height)? Thanks!
I’m not aware of any way to do the first two. You may want to check in the scripting forum for a potential scripting solution.
You can get a measure of the bounding box height and width as part of the report generated by Transform > Analyze Selected Subtool, subject to whatever the scene units are.
Thanks!
