Options for sculpting brick wall displacement on a huge Castle
What are my options when it comes to applying brick wall sculpt to many pieces of a castle. I have in attachment one of them (the watchtower), but need to do it for a very big castle.
I have seen zbrushcentral tutorial where he models 10 different bricks having 4 faces = 40 choices. But then for the whole castle is this the way to go? some use nanomesh (don’t know how to use it yet)
If you had the whole castle each part with a different shapes (some circular like the watchtower, others flat like walls), how would you go about making a realistic looking brick wall in the mesh? I’m bringing a low poly mesh from Maya.
Jump on YouTube and look into NoiseMaker. (Found under Tool > Surface > Noise) You can import an alpha and tile it to the desired size you need.
