I’ve got an older Wacom tablet, its a 6x8 that has the model name of “Digitizer II” on the back - I think its also known as an Artz II. I believe I got it new in the nineties.
It works fine, and it performs with pen pressure sensitivity with zbrush. The only downside is that the sensitivity is a bit “rough” feeling - e.g. I don’t believe I have quite the control that I would with a brand new model. It does have an XP driver that I use that I got from Wacom, so no problems there.
Here’s my question. Being that I have a Wacom, and it has the ability to detect levels of pressure sensitivity while I work, how much improvement do you think I would see by upgrading to something like the newer intuos3 tablets?
I mean, would it be a drastic improvement or would it be just a modest improvement in feel?
For that matter, if you do think it would be a drastic improvement with an Intuous3, would I get similar improvement by going with a slightly older model - like an intuos2 or the original intuos?
What do you think? Should I buy a newer one or just continue to work on my sculpting technique with this older one?
Any input would be appreciated.
Thanks, Ron
