Object Disappears when you move around.
Hi
I’m new to Zbrush 3.5 but i have worked with Zbrush 3.1. I’m having issues where when i move my object around it suddenly disappears! And usually when you double click on “move” it brings your object back to the center but it doesn’t do that sometimes. It looks like there is a camera clipping plane or something. I never had a problem with this sort of thing in 3.1 So i’m wondering what the problem is. Any suggestions would help! Thanks
Which release of ZBrush 3.5 is it? You can tell by looking at the title bar.
You should be using ZBrush 3.5R3, as that is the most current version.
Its the latest. Zbrush 3.5 R3. There might be a bug with .obj files? I imported as a .ma file and everything seems to be working fine. No more camera clipping plane. :slight_smile:
