Noob question - changing lighting direction
Hi guys,
I just started zbrushing 2 weeks ago.
Im a photographer but my aim is to create life-like subjects that are out of this world to place into real photographs.
Ive created a model but am trying to change the way my model is lit so that I can export it into photohop to place it into a photograph. Reason is because the lighting on the model has to be consistent with the lighting in the photograph to make it look realistic.
Ive been doing this through LIGHT >> moving around/turning on and off the additional lights.
However, the changes are not reflected on my model in the workspace at all.
Not sure why it is so, can anyone help?
Thanks!
You’re using a MatCap material, which has a baked-in light map. In order for ZBrush to render changes in the Light palette you need to use one of the non-MatCap materials.
Thanks alot!!
