About the ZoomFit Button:
Here’s a button Pixologic forgot. This ZBrush plugin creates a ZoomFit button (similar in nature to the Scroll, Zoom, Actual and Half buttons) which lets you toggle between any Zoomed-in view and a Full view of your Document. This can be extremely useful when you are working up close on a model, but want a quick look at the whole object. Also should be useful to ZBrushers who work on large scale documents (for modeling or 2.5d illustrations).
When you click the ZoomFit button, it will remember the Zoomed view (scale and scrolled position) and will toggle back to it next time the ZoomFit button is clicked.
Any time you change the Zoom scale or shift the document relative to the viewing window, that will be remembered as the new “Zoomed view”.
Installing the ZoomFit button:
The ZoomFit.zip file contains three files:
- ZoomFit.zsc
- ZoomFit1.psd
- About the ZoomFit Button.doc
The ZoomFit.zsc and ZoomFit1.psd files should be unzipped and saved into the ZStartup\ZPlugs folder.
Next time you startup ZBrush 3.1, you will find a ZoomFit button in the ZOOM subpalette. You can drag this into the right-hand shelf or wherever the other document zoom and scroll control buttons are located. Remember to Save the new layout… Ctrl+Shift+i.
As with all ZScripts, using the ZoomFit button (which is a script) will supercede any other current ZScript. Maybe a button similar to ZoomFit will turn up as an integrated control button in ZB4 so that won’t even be an issue.
Assign it a shortcut key and this button can be very useful.
It tests OK on ZB3.1 - if you have trouble loading it on ZB3.12B please let me know the nature of the problem? Thanks.
Svengali
p.s. - a nod to TVEyes, who scripted Tiny Tools a while back… which included a “Fit” button that gave me the idea to create ZoomFit. Thanks Mark.
